On the road again
Ok it's up and running again (thank God I was starting to suffer from withdrawal) I broke the head off one of the clutch spring bolts so I replaced them all with high tensile bolts and used the same washers. The crank sprocket looked ok so I'll keep the new one for a spare. The front fender is on now so the bike is complete, just the tank to repair and bearclaw. I tightened the clutch basket with the impact driver worked real good back to same position on the shaft. Thanks to everyone for your input and encouragement. The bike sounds good, no rattles knocks or grinding noises and no leaks. I will get the oil analyzed soon to check for problems.
