ozrider
2008 Standard
I plan on ordering some black steel lock nuts instead of a cap nuts that are stock to alleviate the loosening issue.
Ive only ever nipped them up when they are cold after a run, never had any issues of coming loose
THATS TRUEimho you could strap a large black phallus on the end and it would still look better than the stock chrome melon shooters lol.
Beauty is in the Eye of the Beholder, Art some may say the same about the Brutes ...... sorry not my cuppa teaUGLY muffler
Same HereIve only ever nipped them up when they are cold after a run, never had any issues of coming loose
Thanx for this tip, Mate!
I shall go get some 2620 post haste.
Heh heh heh I really I shall purchase the 2422.![]()
You may never want to take your CES system off (I wouldn't if I had one) but just in case 2422 is the go.YES to each his own it seems a lot of riders like to customize to suit their taste even if it kills the power output weve had some crazy designs show up on bikes that came in to be moddedBeauty is in the Eye of the Beholder, Art some may say the same about the Brutes ...... sorry not my cuppa tea
I prefer the look of the StainTune Mufflers because I loved the Original Three Muffler look (the Heat Shield is not finished yet a work in progress you might say) the second picture is before the heat shields, Trevs Welding Art especially the way he modified My StainTune Mufflers to take the 1 3/4 tubes from the reverse merge collector with welds that would rate as impeccable were to beautiful it completely hide so I got some Perforated (so you can see thru it) Stainless Steel and have shaped it as best I can, it still has an edge to be added to it
Notice also that no clamps were needed so it has clean look and believe me they are a snug fit with absolutely no leaks![]()
My system is very free flowing I will be surprised if there is a dramatic difference between mine and a CES single muffler system on a dyno I know the improvement is very noticeable now, will let you know when I can get to a dyno to get it fine tunedYES to each his own it seems a lot of riders like to customize to suit their taste even if it kills the power output weve had some crazy designs show up on bikes that came in to be modded
