O2 Sensor plug
Rodneyjd6
Gold Coast
Rocket 3 roadster
Hi all just wondering i have the o2 sensor disabled in the tune i run a pcv with auto tune should i take out the o2 sensor plug in the pipe and just block it of is there any advantage in plugging the hole up
Removing it will prevent it from fouling up. Some have put in a sump plug and kept the sensor safe somewhere in case you ever need it again.
I would like to recommend using a anti-seize compound if you use a plug. I plugged mine off and couldn't get the plug out later on to reinstall the o2 sensor. Long story short I got it fixed but it cost me extra money. I used what I thought was a high quality plug but found out later it wasn't good enough. Couldn't determine the reason the plug wouldn't just spin back out. It wasnt cross thread that's for sure because I carefully installed it myself.
