Scaramanga
Standard Bore
My Rocket (54 plate) has a just developed a noise from the cam. It has done just over 15000 miles.
Anyone else have this problem and better still a solution.
Welcome to the forum first and foremost!!!! SOunds like you need the upgrade kit form triumph that addresses this issue. More info might shed some light on your problem. Symptoms, year, model and anything else you care to share! Enjoy the site! :D
mutt
My thoughts would be it is possible need the plug in the tensioner to bring back the correct tension on the chain. Worse case scenario is the crank gear has developed slop in it. What year bike is it?
Noisy Cams issue
Chaps.
Thanks for your advice.
It was the cam chain tentioner, not quite on the next ratchet tooth.
A 20 second fix. Engine purring like a contented lion now.:)
