sonny
I am amazed at all the troubles people are having with the rocket. If I were new to this site or just browsing it would just about scare me out of buying a Rocket. Not such the case. Almost 22,000 miles and not one issue with the Rocket X. The only problem I have had with the bike was due to a ill trained mechanic at a dealership who could not even change out a tire correctly. After the fact we now do are own work on the bike. Could some of the problems folks are having with their Rockets be due to aftermarket mods and lack of proper maintenance by Dealerships? I have noticed that a lot of adjustments need to be made on items that are listed on the service intervals. Not just a check and go which I imagine a lot of dealerships practice. Even something as simple as adjusting the clutch cable properly could explain a lot of problems with the bike if not done within specs. A good torque wrench and common sense combined with taking your time would probably eliminate a lot of valve cover gasket leaks. Paying attention to how the bike handles and knowing the tattle tale signs of bad wheel bearings could save a lot of headaches. It is one thing to fix a bike up a bit, it is another to maintain.
