TallRocket
Standard Bore
Hello All,
My name is Tom, 58, 6'10 sub 300 lbs (yeah). Likely the biggest guy you are likely to meet.
Purchased my Classic in April 05, graphite from Mananyuck (outside Philly), PA. Moved from PA to Golden Valley, MN and from there to North Toledo Bend Lake, LA. Bike has been stored for 3 years. Over the last two years have had both knee replaced. (if you Dr says you need a new knee - do it, the pain you feel with the old knee doesn't dimish and the pain of the replaced knee was never greater than the old knee and does diminish over time)
I am begining to plan for returning to riding. I am looking for your input on what I should add to my to do list to bring the Rocket back to life. The bike has about 13K miles on second set of tires with stock tune.
- replace oil and filter ( have both with replacement brass washers)
- replace final drive oil
- check air pressure
- lube cables
- inspect brake pads and fluid
Prior to storage I drained the gas from the tank, but recently noticed a gas like leak from under the tank. So, I need to remove the tank.
My shopping list includes:
Fuel line and filter
final drive oil
New battery ( even though on tender it is still five years old )
new tires
Should I replace the radiator hoses and flush the system?
If I am not bass fishing, I will be on the Rocket. Anyone near the Shreveport, Logansport area on NW LA is encouraged to drop in.
PS - This site is assume, I have been wasting my time watching the old Triumph site
- lube cables
final drive oil
new tires
