Welcome from Florida ,Frank it would be easier for other members to giveyou assistance if you put your location and bike year and model under your avatar.
3rd problem sat for about 3 yrs with old gas
I got tank empty an gas drainded
and wow the response already is great
I'm really good working on cars and trucks wow bikes are a whole new beast
I also just got the obd2 usb and tune ecu but not sure if I want to adjust maps cuz I'm lost on witch ones to use
bike has high flow pipes and cat delete done is all I know
G'day and welcome.
Do not adjust maps until you know what you are working with. First, make sure that the Primary TPS is set correctly. This can be done with TuneECU. The original ones in the 2006 models wore out, but the ones you get now should be good. This is an easy check/adjustment and will probably fix the idle problems, assuming fuel etc is fresh. If it fixes the problem, but the problem then returns, then you will need to get a new TPS.
