El Bruto
.060 Over
- Joined
- Oct 6, 2015
- Messages
- 126
- Ride
- Rocket 3 2005/6 modifed!!!!
I fitted an aftermarket alarm today, its called a Spy5000... wasn't expecting much as its not stupidly expensive..... However.... Very impressed!!!
Comes with 2 intelligent remotes, a knock sensor and an adjustable microwave proximity sensor..
It was easy to install, remotes are a nice quality with a display showing an image of the bike.. and state of alarm..
So.. if I walk away without setting the bike chirps, the remote flashes and vibrates... If I accidentally unset the alarm it re-arms if ignition is not turned on..
If someone goes near the beast it will chirp a warning, and at the same time the remote flashes and vibrates indicating a proximity warning.. if they stay too close for more than 5 sec it goes into alarm state.. Obviously the knock sensor sets off alarm immediately, and the remote informs you its a knock alarm.
It can also start the bike remotely to warm it up, although it cannot be ridden in that state as the motor shuts down after a preset time. Again remote shows if the bike has successfully started.
If ignition is turned on while alarm is set it will immobilize the bike and set off alarm..
The remote has a supposed communication distance of 5000m hence the name..
Had one small issue with 1 cable when installing but tel support was first class and sorted within minutes..
