Need Info on Fuel Pump Electrical Connector + question on discoloration
Bike overheated today. Fan is not starting!! I started a seperate thread but wanted to add a note here.
- Swapped the two black grounds going to the fuel pump . No difference to fan issue but I think I saw the low fuel light come on when the tank was raised.
Perhaps I pinched the engine coolant temperature wire while working on the oil tank leak?? There was a plastic cover in front of the throttle cable pulleys and the temp
sensor wire holder bolted into the same holes.
