Need a picture of drain plugs for an early 05,
mexican
Tulsa OK
2012 Carpenter Silver BACK240
I have 2 different versions now but cant find the earlier ones, doing oil change
There are two versions the earliest 04 - 05 Silver engine only. Not yellow and red highlighted plugs will drain your stuff.
Late 05 and up silver or black below oil plugs for oil change are highlighted yeller
Scott, i have one plug under neat and the 2 on both sides, thank you Sir!!! you are my hero!!
Just to make sure, the picture with the littla arrows is what we are talking about , correct??
I have an 05, must be an early one because their is only one 8mm plug up front with an o-ring and a washer on it, do i need to remove the front and rear plugs which are totally different because they come out from the side of the pan like housing? mine is like a jigsaw puzzle and nothing like the simple removal of the three 8mm plugs, any assistance will help lots "Thanks and be safe!
