Paul Jacobs
Bald is best
Thanks Guys,
I have a ELFR-1 Flasher relay 0.05a-10a which replaced my original relay which stopped the 100mph flash.
I had LES's in the front and bulbs in the rear.
I’ve now done the supercheep LEDS at the rear and whilst the indicators work fine at the normal rate the green flashing dash light only dims and brightens does not go out when the blinkers are on.
I have put the old relay back in and this works the same ( dash light not out) only 100mph faster.
With regards to polarity the indicators will only work one way so I don’t understand the significants?
I’ve gone for the new LEDs as it appears the rear indicators have to be a minimum of 300mm apart and my previous set up wasn’t.
Any thoughts greatly appreciated.
On another note I will see some of you local guys on Monday.
