lamber sensor
hogweed
Warminster Wilts .UK
Triumph Rocket III 2004
does anyone know what thread the lamber sensor? is on the exhaust header pipe and also how do you disconnect it,cheers :? :?: :wink:
That the O2 sensor? O2 sensor is an 18mm thread, can disconnect using tuneboy ( click the disable check box & disconnect the connecter clip under the right side pannel)
Same as an M18 oil drain plug.
Dunno, look up the specs for an M18 plug, that'll tell you. 1.5 or 2.5 I imagine, probably 1.5
