barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
Nat - on a standard block a RAMAIR flows more than enough. But aesthetics may dictate other options. If you go for fully exposed K&N - make sure you fit the rain covers. Apart from the obvious plus - they will reduce the clean/re-oil frequency. And should help keep your knee cleaner.After 5 years my Ramair filter is getting shabby to say the least . I am considering the pros and cons of fitting pod filters thru a cut bear claw , a look I really like . The KnN 40-40s would be the best bet but I have a left knee snagging problem . To this end , I definitely need an offset flange , the only ones I can find are the RU 1770s with a 20 degree offset. Has anyone used these ? I'm not sure the airflow would be enough with the shorts , which are 4 inches or thereabouts , so considering the 6 inch ? Any help here guys would be greatly appreciated !
My POV is that leaving the claw on is what keeps my left knee clean-ish. Have tried all sorts of open filter and always end up with a well oiled left knee.
