Indicator flasher unit
captain jack
Turbocharged
UK North West Cheshire
I have ordered this device in order to cancel the indicators (I sometimes forget) it's an age thing you know, brain gone. However it replaces the original flasher unit but will someone please tell me where it's located on the bike ? here's the link
ROCKET 3 SELF CANCELLING FLASHER UNIT Signal Minder SM-1
cheers all, look forward to your replies telling me how stupid I must be for having to ask. :eek:
Good install write-up here:R3 Owners.com :: Log in
Don't know why the link says Log in, but the link should take you to the topic
Thanks guys, in order:-
JRock the link takes me to the log in page but a search comes up with no info found. Any chance of another link. cheers. As you were the link just took me through to the install, cheers JRock.:D
Rocket Daryl, I guess it's only fitted on the R3T, mines a classic only 6 months old It's not on that.
It's under the right side cover. Pull the cover and you will see two relays looking at you. The flasher relay is the one on the right. Turn your key on and turn signal on with out bike running. You'll hear the turn signal flasher relay clicking.
Thanks all, I've checked out the flasher unit & wiring harness, found the blue switched live wire feeding the brake light as in the install thread, all I need now is the unit to be delivered. :D
Captain Jack,
I also have a classic
Its behind the side cover that is adjacent to your right leg when you are on the bike.
Its the forward most one of the two relays (the other one is the starter relay)
Hope this helps
Tony
Flasher relay arrived today, fitted ok no problems & working ok, not done the switch self centring bit though, to messy. Also fitted my GIpro ATRE which arrived at the same time, what fun & a nifty gear indicator too. Thanks for your help all that answered.
just sent you a pm, was wondering if you or anyone else know if the tailblazer and pathblazer (front light modulators) are legal in the UK?
i may be importing my R3 there in april...
