Daman
So i did manage to check the bike using the incense method.. seems to be a good joint for now. Also this was the first time i rode the bike after installing the Jardines, what a change!!
I'm still running the under the seat OEM filter, using the tuneboy for the Jars. Seems to be working well so far, lots of power and great sound.
There was some popping on deceleration, tried fixing through the A/F tables in tuneboy and that certainly helped. Still some popping around the 1000-1500 rpm range, but greatly reduced from before. Probably need to experiment a bit more in that rpm range.
I don't want to switch to the triple k&n's for now.. would the under the seat K&N be any better than the OEM filter?
Cheers!
Cheers!
