HI.. "IDK"
as far as my research has gathered, indicators and fuel management and 20 other problems all come under this "P0705" Fault code.. still trial & error one by one, so far, thank you.
i'm on my 2nd "TPS" when stayed at 3 & half thousand revs, this one is all over the place, with the fuel, now running on 2 cylinders to.. I've tried a
Tune ECU with no luck with the connection,
hence brought another one to see if any different, whether better or worse, but again no answer, thinking problem with my ECU..? SCRATCHING MY HEAD A LOT THESE DAYS,!!!!
LOL..
I know I like PUZZLES..!
But this one is starting to forget SCRATCHING my head, to tearing my hair out,
GRRRRRR!!
LOL..
AS for indicators, i've swapped flasher unit a couple of time, from ORIGINAL to OEM..?
NO DIFF..! I HAVEN'T CHECKED on turning switch as of yet, all connections are good thou,...?
so back to handlebar switch or FAULT CODE..?
I like
WARP 9.9"
comment with the GPS.!
GEAR POSITION SENSOR. FOR FAULT CODE P705 make a lot of sense and covers the code answer so far,
as i be doing this first, I'll let you all know how i went..?
THANK YOU ALL SO MUCH
for all your help, experience and information..!!
