Welcome from Canada. The revving up will be a faulty Throttle position sensor. Common on the early bikes. The revised TPS has blue innards
TA, HAVE REPLACE THAT ALL READY, THANKS, STARTING to check out fuel management and other electrical probes thanks
connected to FAULT CODE "P0705" which from research can cause twenty problems... 2 out of 20 so far and counting, lol
thanks
Welcome from Indiana Mal. Sounds like you've already got some good advice to start diagnosing and resolving your issues. I wish you well with that and many happy miles thereafter!
Welcome the 0705 code is for GPS gear position selector Yours is old style might just need a bit of cleaning.
see the contact points below the small one is neutral the others are the gears Scotch Brite works well on them
when you pull it out watch so you do not loose the contact pin/plunger on the spring
Also check and clean the connector to the GPS which I believe is behind the little infill panel on the left side right at the back of the engine.
Now your rpm problem sounds like it gets stuck at a high idle 3 K or so and of course does not idle stable when at lower rpms. If this is the case put a new Primary TPS (throttle position sensor which sync's the throttle opening with the ECU) in her do a full ISCV reset and while you in the ecu check the throttle body balance and adjust if needed. As for the turn signal problem I am not much on that but if it were me I would run down to the auto parts store give them the turn signal relay (behind side panel right side of the bike right behind the ECU with the starter relay. Cheap way to eliminate that as a problem >
Hope this helps and welcome aboard Mate
THANKS for that WARP, I'LL PAST IT ON TO MY NEW MECHANIC, as for indicators, have done, even re-wired one flaser with pins different, but flashers not the problem, what ever it is I've permanent HAZARD LIGHTS NOW, LOL ...
Which isn't bad for the CAGE DRIVERS, BIG HAZARDS, MMMM THEY CAN SEE ME, YIPPEE..LOL
welcome to forum. What are the lights you have on back of bags?
LIGHTS ON MY BAGS,are combined BRAKE/TAIL With indicator 8" inch L.E.D.S from any shop, with aluminium surround light tilt from and old AMBULANCE that tilts the light down to ground.. looks good, not bad for a bit of this and that, lol
Hi Malcolm, Welcome form exotic Idaho. You can take Warp9.9 advice to the bank. What is the 3rd gage over your Speedo/Tach ?
Bill
ta, Bill, the gauge is just fuel, the previous owner spent money, on it had a crash, repaired it, brought a house on dirt road, he did 9,000kms in 3 years sold it cheap to me and Idid 9,000kms in 3 months...that was 7 years ago... i got the better deal, lol
althouigh I've had a little bit to to it, dual battery, alarm, tracker, hand made bags, crash bars, 10w LEDS to front, brake/tail/indicators to bags, 12vdc to bags, backrest modified to standard seat, sports seat,GPS, CRUISE CLAMP,car tire,, still more to do, but first to get it purring like the ROCKET IT IS.. MMMMM
i MISS IT..!! LOL I'm starting to sound like a demented old fool, missing my bike, lol.. even thou, i'm single for years, lol have 3 beautiful grandkids, a dog....
I STILL MISS MY BIKE.... HA HA
