Mine was an '06 and I loved every minute of it till a touch of decelerating head shake in a left hand turn became a tank slapper at 30 MPH. I lerned the value of a good jacket and full face helmet at that moment. Straight line accelration was wonderful and cornering was ok; just don't try to keep up with the dedicated sport bikes in the mountains on the curves. Catching them in the straights is no problem. With a gentle hand, I could get 130-135 miles out of a tank, but normally only got around 100 miles. If you get one of the older bikes (Pre-2009) you need to add a fork brace to stiffin up the forks and a frame brace to stiffin up the chasis. Some guys will swap an R1 front end which does help a lot. But keeping it stock and staying within its limits on the twisties is just fine. Adding a big screen will ease the wind blast starting around 65 mph and make 85 mph cruising nicer. If you ride a pillon, get a back rest to keep them on the machine under acceleration. DO NOT mess with the "V-Boost". Many guys will modify it to be ON all the time. This kills you low RPM torque. It is best to keep it stock for max power unless you go full retard and build the hell out of the engine.
