Help! TPS issues
Bishop
Turbocharged
2005 Rocket III
Idle stepper.
Also, when you've adjusted your TPS, did you torque the screw to 3.5nm?
See this thread regarding TPS:
Assuming you have a TuneBoy?
What other mods?
So you're just winging it with a multimeter on the TPS or does the PC3 give you that data?
You need to do the whole procedure as described in the manual. TPS is only one part of this.
The idle stepper is the other.
Best thing to do may be removing the idle stepper and see what happens.
Disconnected my idle stepper motor from the throttle bodies, but kept it wired in - just cable tied it up under the tank - cured all of my idling problems immediately.
There's a 'How To' on it I followed.
