Help ? PC5 +Auto in OHIO
Maybe they could rename the business to www.MoreMushroomPower.com
Sorry trying to see the funny side..
So Are you saying the that even though they told some one else that you can now they say to you you can't .... geez I'm getting confused
hanso your not alone
If a couple or more have PC5 fitted to 04/05 and EWS is telling us his is working fine then you must be able to connect the harness plugs....
there is no question it works, I installed it out of the box with no additional adapters whatsoever. It is true that all harness/ecu plugs with the PCV and autotune are simple plug n play. I am not a power commander salesman just a satisfied consumer that is trying to reassure others they can also have a positive experience.
make sure you are ordering the power commander part #21-003 and autotune part # 1020-0923 AT-200.
also you must have access to a windows based computer as I operate from a mac which is apple based software and even though i use some conversion software to run windows programs I had to resurrect my old laptop to operate the power commander software which is windows based.
LOL you must be able to read minds I was just about to ask you about map files and this popped up
Can I ask where you mounted the modules?
Thanks for that Eric, I have both XP (on my 10 inch Laptopwhich i also use for TumeECU) and windows 7 on the other, will the PCV software be OK on XP?
Just a question I read on the PC web page that you could via switch run two maps ie 1 for touring/ economy and 1 for Power/having fun is this the case or just a waste of time
I used windows xp and I'm not sure about windows 7. Yes the dual map is possible but you need to buy a switch that plugs into the autotuner. I did not go that route because I'm not obsessed with 2-4 mpg. Not to mention that inevitably 15 minutes into a mileage/long run I would want to have a 15-20 min spat of craziness and mid-ride I don't like the idea of flipping tune altering switches. Most of the fuel savings comes from one's tendency to or not to flip the launch switch on the right handlebar.
Yeah I gotta agree Eric!..... You just never know when a Crazness urge is gonna Hit ya....... what was I thinking.... Sorry guys sometimes I kid myself about being sensible... yeah right!!!
Works fine with windows 7 also just confirming I have Pcv and my software is on a windows 7 system and all is good.
Sent from my iPhone using Tapatalk
Thanks Mitch
