Handle Bar Buzz
Micksan
Del City Ok
Love the bike but, I get a buzz from the handle bar. Mostly on the right side. Will put my had to slep. Changed the grips to the foam type. Helped a little. Anyoone tried Gel grips??? BTW not a medical problem , No problem with the Vstrom 650.
Just a thought.. maybe vibration transmitted throught the cables if its only on the right side.. maybe try a cable tie or 2 along the length ??
Check your front tire air pressure. If you're running 41 psi, take it down to 38 and see if the vibration is changed. If so then your front end, not your engine is putting the buzz in the bars.;)
