TriumPhil
- Joined
- Oct 12, 2009
- Messages
- 11,444
- Location
- Long Valley, NJ
- Ride
- '07 Mulberry Red, Carpentered & Bruted R3 Standard
Falcon, warp 9.9 (Scott) is giving you the straight dope... he's really one of our #1 go to guys here for tech/mechanical advice and he's forgotten way more than I'll ever know about motors or wrenching on them.
Yes, you should first try to research the provenance (prior ownership) of your Rocket to see what, if anything, might have been upgraded. Others here will share with you the symptomology of those things or parts that might begin to fail or go bad over time, so you will have a heads up or know what to look or listen for. As Scott said, you might be lucky and have a perfectly fine motor, too, so stay cool, calm and collected while you both learn and ascertain the fact!
As far as fixing the TPS is concerned, for a long time Triumph was picking up either the part cost, the labor cost and occasionally both, so if you will be employing a Triumph dealer to do the fix for you, it's worth inquiring whether they still might prevail with Triumph corporate to pick up some of the cost. Slim odds of that at this juncture, but definitely worth the inquiry.
