The only thing that would prevent you buying a perfectly good Rocket x would be an unrealistic high price....with 500 on the clock it is basically new....should have nil problems at all...go for it ...
Thankyou guys. All goes well, it will
Another quick Question, do i need to get it serviced and get oil changed before i ride it, as the seller and nearest service station is over 250kms from my place.
Thankyou guys. All goes well, it will be home soon next to the Storm.
I would...it may not have been done as yet and in that case will still have the "Running in " oil in it.
If you do it then you will be sure that its done and you can rest easy.
Have the dealership do the check for you...all the nuts and bolts etc will be checked to ensure everything is tight and correct...tyre pressures correct etc...get your service book stamped.
