HeR3tic
Is it possible for Triumph to devise a double or triple lead adapter to accommodate a 5v GPS unit and whatever you might add with varying voltages. You don't own a volt and ohm meter? $5 bucks tops for one you can throw away in 10 years, unless it is Crafted Hardware In North America through outsourcing . I've tried to get a picture of the device you're speaking of and haven't found it. I suspect you're looking at 12 volt output on the leads. I once thought I was wrong but I was mistaken
You know, protectionism is really synonymous with sovereignty. And you Tea Party goers are on the main frame now.
Now, if someone would engineer: An under tank harness with several (3) user selectable or intelligent regulated voltage adjustable assembly connector, that would enable a nice finished wire bundle up front. You could have your DVD, iPod, GPS, and butt massager (definitely 12 volt battery direct) all controlled by an LCD touch or audio controller. Why not a Heads Up display with mind controlled screen images. You think sex videos and up pops an image of you and your Beast lighting up the darkside
