Fatty
Standard Bore
- Joined
- Mar 22, 2020
- Messages
- 1
- Ride
- 2013 Rocket III Touring
I have a 2013 Rocket 3 touring, about a month ago, I was down to 1/8 tank and filled up, When I left the gas station, I slowed down to turn and the engine stalled, I restarted and went on no problems at all. I have almost 750 miles on it without a problem since, and today I was down to almost completely empty, filled up, and it was stalling at every time I would let off the gas at all, even when going at steady throttle. I loosed the gas cap, and the problem went away. Then it happened one more time after I came down a large hill, where I was using the engine as a brake. Does the cap have a breather built into it? Should it? Would getting gas make that quick of a difference?
I should mention, I had stock pipes on it the first time it happened, and now have D&D pipes on it, seems to be worse with the new pipes.
