fournales air shocks
berrypicker
scotland
021.jpg picked up a pair of second hand air twins and the hp stirrup pump they had been fitted to a honda gold wing there about an inch and a half longer , had to get one mounting bush modded as it was smaller id the other three bolt straight on (similar to a rose joint} initialy they were topping out on the rebound so undeterred took em apart (you have to send em back to France every body told me ) really easy once you make the tools inside their very simple ,put em back together filled them fully extended to the brim with 10,40 engine oil then compressed em fully to get rid of exess oil this was a rough and ready guide to filling them ,fitted to bike pressured to 15 bar ,totaly transformsd the bike handling wise bike turns faster with its ass in the air and the rebound is now perfect lots better than the oe shocks ,vive le Francais first ride today once the frost melted cold but grinnin lika a demented cheshire cat lol
Hat's off for the rebuild. 325mm is what mine came as.
Fournales suggest 17 bar btw. But yours look like standards rather than the magnums so maybe a bar or 2 difference is to be expected.
ime most air shocks top out with a great deal of ease. I've always set them up with very little static sag.
tad hard at 15 bar solo perfect two up have two tufnol split bushes inside like fork bushes a green seal for the air and a convential seal without the spring to keep oil in repolished the hard chrome coating in the lathe with metal polish and twine to remove minor scuffing ,had a stainless split clamp which i machined to the od of the alloy section that holds the seals cant use a vice, a lathe chuck ,or stilsons:shock: sacre bleu,youl crush it oval and itl never seal again ,fortunately
my seals were good , i dont know if fournales would sell seals as a service part nowadays but i think they will be fairly standard anyway outa some french tracteur or grape crushin machine
Viton possibly. I've had to deal with some 300Bar systems in the past - Viton lasts a long long time. But again - :Tip-Hat:
Mine are a bit soggy at 15 - I have 17 and a bit (the needle is just past the 17 line) in. I have the Alloy (HD style) Magnums - ordered direct from France - About 650Euros iirc. Came with a pump too. I wish I could convince them to do air forks.
ime - Air shocks feel different to Springs. What feels hard on air is actually actually often really too little air and visa versa. But whatever feels right is good. :thumbsup:
I really must refit Airshocks to the Guzzi.
Fournales are marvellous, except if you want to adjust them for a passenger. I've also got the Balck and alloy HD alloys.
Mine came from France with 19.5 bars in and I used them like that for 1500 miles around France and Spain and even pumped them UP because of all the luggage we had on the bike. They coped very well with a trip into a ditch in the Picos Europas mountains, where I fell off and a major 6 reversals tank-slapper on a white painted, diesel covered wet road in France, where I didn't. I had no trace of my usual back ache for the whole trip and this was not because the pain from my broken leg, from the first day crash, overpowered my back pain. I threw the bike around quite a lot of twisties with a passenger, full panniers and a really heavy GIVI top box, with a bag on top of that.
Now I pump them up to about the same, just over 17 bars and leave them like that, even with a passenger. At 18 bars the rear wheel tends to skip over bumps, the bike feels heavier when flicking side to side for turns as the pressure goes up. At 16 bars I find the bike is nice and floppy into bends and feels a lot lighter side to side but the rest scrape a bit. They do respond to preload differently, dropping the pressure lowers the ride height but will give a harsher ride, increasing the pressure will bring the back end up higher, improve steering response and give a more sports bike ride with better feed back, although will tend to make the rear wheel skip over bumps at high speed.
I like the convenience of standard shocks for the adjustment otherwise, Fournales are the best thing I bought for the Rocket, apart from the Staintunes, PCV and Autotune.
The shame is that (at one time anyway) Fournales do (did?) MONOSHOCKS with a remote air tank that you could isolate (effectively firming up the spring rate) with a valve, to allow solo/with-passenger at the push of a button.
I asked (near pleaded) - but they would not do them for twin shocks.
Find my beastie is far more responsive (lighter in the twisties) with more air in - not less - but I've always liked firm springing and light damping. And I've come to realise I'm not really a cruiser rider.
I hope to have a chat with my mate Nicolas about some for R3 fork caps with valves in. 1/2bar of air in my Guzzi (FAC cartridge) forks made a hell of a difference.
18bar must have them topped out on the side stand. I have just a hint of static unloaded sag.
Hey thats a great idea wouldnt be hard to link the shocks together using swagelok or similar fittings could have a small air tank pre charged and operated by a solenoid whats the pressure rating on them small diy welding gas cylinders
Dontt forget that if you add a BIG bottle the risk of bottoming out will increase. The fournales add ons are tiny
