Still the same engine, still the same bolt holes in the engine ... just a matter of swapping out the lower engine guards like any other R3. The only possible difference will be the brake line, and those are same-same only with different bends. You can either swap out the brake lines along with everything else, or just bend it to fit. If there is ABS involved, swapping out the lines won't work if you use an older assembly.
