Fog wiring harness - Switch?
dd14x
.060 Over
Texas/USA
Hello, I'm looking to add fog lights to my 25 Storm GT. Looking to buy a wiring harness to connect to, but am struggling to find one with a handlebar switch that will fit the handlebar. The handlebar seems to 1.125" in diameter, but the switch mount seems to max out at 7/8".
Has anyone found as switch that would fit the GT's handlebar?
Not exactly what you're asking for, but an alternative to the handlebar switch that I did for my marker lights (right) and USB charging outlet on left...
Thank you! I am looking for a handlebar switch like the one that is on the harness at this link https://www.amazon.com/gp/aw/d/B091HHH7MT
7/8 inch won't wrap around the handlebars
Also, unrelated - at the link you posted, you indicated that you upgraded the OEM headlights - what did you go with?
Thank you! I am looking for a handlebar switch like the one that is on the harness at this link Amazon.com: Nilight LED Light Bar Wiring Harness Kit Motorcycle Handlebar Push Button Switch 16AWG 2 Leads 12V On Off for ATV UTV Driving Lights 7/8inch : Everything Else
I went through a couple of different marker lights before settling on the ones that link takes you to and very happy with those. I think they all came with a handlebar switch like you pointed to, but I preferred not to have that look, including the wire running up the bars.
I still have the OEM headlights. I'm not sure where you saw that reference, but I might have misspoke and was probably referring to the marker lights.
It's hard to find lights with the correct sized handlebar switch....I was not able to find anything. You're going to have to splice it. I used this Custom Dynamics switch for a project, but it took up space I needed. So in the end I went with this bracket switch
