Fitting an Alarm
Don't know what's available to you in OZ but any aftermarket alarm installation is pretty much the same - find and splice into brake,turn signal and ignition wires. Not real hard if you're comfy with splicing into wires. If you're not comfy with finding and splicing into the appropriate wires, then you'd best get the Triumph alarm or one from a maker that also includes a wiring harness for the Rocket (none do that I know of), so the install is just plug-n-play.
I've had the Aritronix Scorpio SR-i500 for near two years now and I can't complain about anything. http://www.scorpioalarms.com
If asked for improvements I'd want the 2-way remote pager with longer range. Their service is tops though. I found the alarm reciever antenna severed probably because of excess rubbing on the frame (tie that thing down!) about 18 months after having it and when I contacted them about a repair, they told me to send the unit in and they'd see what they could do. Just a couple days later, they sent me back a brand new unit at no cost. Awesome!
