Toystoretom
- Joined
- Feb 25, 2006
- Messages
- 2,449
.65 is close enough.... it will even change when you get the bike started. That .6 volts is just a "base" setting but it should be close to that. The .48 is because the battery voltage drops when you crank the starter (it puts a load on it) and really... just for the few seconds that you crank the starter I would consider this normal.
It doesn't sound like the TPS ect. is causing this... you may have to re load whatever base tune you are using (20050?) It sounds like it may be corrupt.
