MountainMan
Well, I went and did the mods - Jardine complete exhaust, Triple K&Ns, and a TuneECU tune on my '08 R3T. Those were the easy ones because there are lots of instructions and how-tos to get those things swapped out and off and running. The *****y thing seems to be the removal of the evap canister (included on my bike coutesy of the State of California). For those who have not seen one, they are mounted under the left side cover and take up a bunch of room.
The first hose goes from the evap can to the fuel tank vent. That one has been re-routed to the hose exiting to the underside of the bike.
The second hose is a vacuum line that hooks directly into all three throttle bodies on one end. On the other end, it hooks into an electrified valve mounted below the big evap can.. These have been diconnected at the TBs and the TBs are now fitted with plugs.
The third hose is connected only to TB #3 behind the throttle plate (same as the other vacuum connection). The other end hooks directly to a switch/valve-looking thing on the rear of the evap can. I plugged the throttle body side like I did with the other vacuum connections.
I just left the wire connection hanging and unhooked. The connector is of the two-wire variety.
OK, here's the questions:
1). Did I unhook this apparatus correctly?
2). If not, what do I need to do differently?
3). Where else should I look for causes of the Check Engine light. (no, I haven't ventured into the unknown realm of looking at codes on TuneECU yet).
Thanks for your response.
