Planning to hard-wire a GPS, radar detector & a phone charger into my R3 Classic, each with an in-line fuse & quick detach BNC connectors. Any suggestions as to where best to tap into the electrical system? Also, would like to tap all 3 into the same location if possible. There is a zero chance that all 3 items will be used at the same time but a very good chance that 2 of the 3 will run simultaniously. Here are the radar detector requirements:
11.0-16.0 Volts DC negative ground
225 mA typical standby, 425 mA maximum
alarm condition
Thanks,
Eric
