Heisenberg
Well, guys, I've experienced that high idle problem recently and was pretty scared with the potential difficulties on my way to light-hearted riding. Thanks to this forum and especially Tomo - I've found the fix. The point was to set voltage on the TPS as it sometimes goes crazy. The thing that inerested me was that turning the TPS changes the voltage. So I maid as follows. Turned on the bike, losen the screw that fixes the primary TPS and turned it round. The hole that is used to fix the TPS is some kind of oval so it is possible to turn this unit. Turning clockwise makes poor idle, turning in opposite direction makes high idle. As I don't have any special tools ang gauges I've used the tachometer to set the idle I need, that came from about 3rd attempt but still bike runs perfect now.
My idea about TPS is that it could be not bkoken and sometimes there is no need to change it. As there is possibility for it to move round that could be done just because of the engine vibration. And if you turn it round you could notice that even small movement influences the idle a lot.
Anyway I will do verything right when I get some gauges and software. But this fix is extremely easy and hope that will help many Rocketeers to enjoy their rides for longer time and especially when got down by the issue during long trips.
