Yipa Standard Bore Joined Mar 29, 2023 Messages 1 Ride Triumph rocket 3 Mar 29, 2023 #1 I have coolant leaking from water pump housing I have nipped it up but still leaks, is this a common problem?
Tal Living Legend Joined Dec 20, 2015 Messages 5,826 Location Christchurch, New Zealand Ride 2021 Triumph Rocket 3 GT Mar 30, 2023 #2 dont think so....
bikecrazy .020 Over Joined Dec 13, 2022 Messages 21 Location Eastern Washington Ride 2005 Rocket III Mar 30, 2023 #3 That usually means you need a new water pump.
Rocky Raccoon .040 Over Joined Jan 21, 2023 Messages 81 Location NW Montana, USA Ride 2008 Rocket III Touring Apr 9, 2023 #4 Yipa said: I have coolant leaking from water pump housing I have nipped it up but still leaks, is this a common problem? Click to expand... I have the same issue after the bike sitting in the unheated garage all winter..... hope I did not crack anything,
Journeyman "And this one is just right" ~ Goldilocks Joined Aug 13, 2017 Messages 2,598 Location Old Fort, NC 28762 USA Ride 2020 3R Apr 9, 2023 #5 +1 on the water pump, unfortunately. Unless the leak is coming from a hose above. I'd run a flashlight around and behind the hoses to look for leaks originating from there- just in case. That would be the "trickle down theory."
