Coolant Choices
I wonder if this is really a big deal and more like Triumph changing their source for coolant- like they have with oil in the past. Changing oils from the recommended brand certainly won't hurt your engine, but the advice not to mix different brands is probably good (but likely not that crucial either, as far as causing some kind of significant damage).
The new coolant says...
"D2053 OAT coolant contains corrosion inhibitors and antifreeze suitable for aluminium [their mis-spelling] engines and
radiators."
Pretty well describes the previous stuff too, doesn't it? Are the new radiators a different kind of aluminum?
To be safe, if you're topping off you should probably (?) use the same stuff. If draining completely to bleed the clutch or set timing, for example, I would just put in something that won't hurt the radiator and is affordable. like the Zerex.
The reason Triumph gave for the change is to increase the service life of the coolant from 3 years to 5 years.
Inorganic acid salts (silicates, phosphates, borates, nitrites, and amines) only protect for 2-3 years. Organic acid salts aren't quite as protective but do protect for 5-10 years.
Side note: "Aluminium" is the Bri'ish spelling, so not misspelled--just different.
Correct. All this BS based on scaring folk. Well, I don't pay attention. Like I said, flush then put what you want in.
MANNOL 5 Litres Coolant G13+ Antifreeze 4214 SAE J1034 High Technology Ready To Use Solution​
just bought that on amazon £12.29 . looks a good spec i may be wrong ,
Just what is the motivation to use any other coolant than stock??
Primarily, availability. IF you can walk into a Triumph dealership and get coolant than that may be the best option.
I dare you to try to get a single shim that fits everything from Bonneville's to Rockets from a dealership. They order everything- also why bikes sit in the shop for so long gathering dust. I tend to order parts from Hermy's (still a wait) and coolant (shipped) would be cost prohibitive.
Like motor oil, if it meets the specs IMO it's fine whether it says Triumph on the bottle or not.
