RooK
First things first.
I'm reassembling the clutch and I noticed some wear from the springs on the pressure plate. Should I worry about this or is this typical?
It's quite hard to say exactly what is the depth of it. (See pictures)
Then I noticed what appears to be a hairline crack in the inner basket radiating from the bolt threads.
So the question is, is this just regular casting or again should I put this on my shopping list too?
Lastly,
On reassembly, the nut doesn't fully thread so it partially sticks out of the shaft therefore the wavy washer sits on the nut lip. Now I don't have a picture of before, but it just doesn't seem right, I can swear it should thread another mm or 2 in. RIGHT?
The crank gear and the clutch gears are even at the front, the crank gear was a little wider at the back.
The outer basket is fully inserted into the oil sprocket drive and I didn't remove anything behind that.
Am I paranoid and this is all normal? It just doesn't feel right to me.
Given the bike history, It's not impossible that there is an extra washer behind the oil sprocket drive but I can't find a parts list view of that in the shop manual.
I'll post a couple more pictures in the next post.
Lastly,
