Campbell Exhaust
Looking good Steve.
How do like the Fast Gun seat? Does it give as much support behind you as the Dualtour?
Nice piece of kit in the background mate.
Thanks Perds, the seat is called Young Guns its a bit longer than the Fastgun, I reckon the shape of the seat is the same as the Dualtour that I had off you, firm but comfy and plenty of rear support.
Steve S said:
Fitted this today, top hand made piece of kit.
Hi Steve, i have just ordered a set of these, What was it like removing the standard exhausts and Cat ? do the Campbells just bolt straight to the Single Manifold outlet and finally, What do they sound like with the Baffles in (or out if you have tried it yet )
Cheers for any help you can give me.
Cheers for any help you can give me.[/quote]
Trumpet, my stock pipes had been on and off a few times so nothing was seized up, depends how old your bike is but the clamps should come off with some wd40 the bolts are 12mm socket size, the Campbells are a slip on fit to the single header outlet, I found the new clamp that came with the pipes wouldnt tighten the joint enough so I used the stock packing ring between the clamp and the pipe, I found them a bit quiet with the baffles in but too loud for me with them out so I have opend up the inner ends of the baffles and refitted them, if you remove the baffles only take out 3 bolts on each end cap the other 3 are dummies.
You wanna see the oldguns seat its got a built in commode with a rubber ring that you can inflate/deflate depending on the state of the old farmer giles :lol:
xhdskip said:
didn't the old rocket or hurricane have an exaust like that?
The X75 Hurricane had three mega's like mine :wink:
http://www.r3owners.com/viewtopic.php?t ... pipe+zorst
Les 8)
