Brake and clutch lever pin
rainman
Seabee can do
niota tn
06 classic 2012 victory xr
Looking for a little longer brake and clutch lever pins so I can put the hand guards on
The original pins are 6 mm x 1 what I need is bout three quarters to a inch longer I been searching on the internet and just can't seem to locate any
Any help would be greatly appreciated
I doubt you are going to find "pins". You'll need to fit bolts. Whip one out - measure the shaft length and add 19mm (.75").
If it were me I'd go for a domed head allen - Be careful NOT to over tighten.
Again if if were me I would look for one that has an unthreaded section for a shank.
If you cannot find one that's exact - get one that's longer and dremel a bit off.
