NicholasRocket92
Standard Bore
- Joined
- May 26, 2026
- Messages
- 8
- Ride
- '22 Rocket 3 GT
So I previously posted about my 2022 Rocket GT throwing codes having to do with the ABS system. I disconnected the battery for a couple days because it was making a weird noise while off and acting very strange, so I disconnected the battery until I had time to properly go over it. A couple days later I reconnected tbe battery, turned it on using the power button, cleared the codes via TuneECU, turned it off and back on, and started it up with the codes not coming back. Everything seemed to be fine and all is well until it started not wanting to come on via the power button anymore consistantly. I would have to press it several times before it would finally come on, until now it wont come on at all unless I press the ignition/start button and then it will wake up and start. No codes and nothing on the dash indicates anything is wrong. It wont turn off with the power button either and I have to use the kill switch on the left side of the bike. The attached photo is the previous codes that it was throwing but those have gone away without returning. My guess is the power button itself maybe has a short somewhere or is just toast?
