Bike has several codes after fuse blew
Well waiting time it is i guess. I called a different dealer who i wish wasnt two hours away cause he was super helpful. I told him the abs code that was showing. Thats not even in their service manual apparently. But I tried doing a key switch clear he told me to try and nothing changed. I had to turn off and on 40 times. But he was stumped with all the information I gave him. I may just take a Uber back home and then to there when its fixed. However im sure a buddy will at least take me to go get. Thats if I dont wanna wait til October and avoid the crappy local dealer I have.
According to the research I've done the C1671 fault is the rear wheel speed sensor fault, which can be caused by an open circuit (wire cut), short to ground (signal not passing to ABS ECU), short to power, invalid wheel speed signal (sensor to ring distance). Assuming you haven't changed the sensor to ring alignment then the answer has to be in the wiring. Any ABS fault that doesn't clear will prevent cruise control from working, no matter how many times you run the switch check.
Recommendation:
  • Inspect the rear ABS sensor wiring again Even if repaired, a single broken strand or poor solder joint can cause intermittent faults.
  • Check the connector at the sensor Make sure it’s fully seated and clean.
  • Check the sensor gap If the sensor isn’t perfectly aligned with the tone ring, it will throw C1671.
  • Clean the sensor Light debris or metallic dust can interfere with readings.(Electrical cleaner is safe — but don’t soak it.)
  • Clear the code and recheck If it immediately returns, the fault is still active.
Visually inspect your speed ring and see if it has any rub marks on it indicating the sensor is actually contacting the ring. That happened to me on my Thruxton R.
