Bike gone funny
Hi Nev i understood that but got lazy as there were 6 plugs, so regretaably just unplugged coils instead..
do you think it would be a good idea to clamp a digital tacho on the plug leads individually and monitor which ones are firing/misfiring?
There were fault codes which i cleared, an ignition circuit fault for cylinders 2 & 3 (i had the coils disconnected on them, but only pulled the leads off the plugs for cyl #1) and a fuel pump error (i removed the pump relay). clearing the codes didnt make a difference in this case.
Also the misfires which kill the motor happen only when around idle... open up the throttle and all is well. I must check throttle position calibration on the PC5.
There is a guy who can do dynojet tuning but I like to have a live AFR on the whole time - for example the PC5 went dodgy back in January and ran very lean (discoloured the exhaust flange bolts), i only spotted it due tot he AFR gauge. Updating the firmware on the PC5 fixed it.
if a bike is firing on only 2 cylinders, does it cut out or just run weak?
ok good to know, i was wondering if i had a dead coil or somehting. it still goes like a scalded cat, just rough around idle and ignition will intermittently die for a sec when revs are anywhere from idle to 2000rpm or so
i wire brushed, greased and recrimped the coil connections and it made no difference. wondering what to try next
