Be aware - Thunderbike
rkt88;
Can you take a picture when you have time, and post it so I can see how you mounted the gauges with the P-clamp?
..just get yourself a Kuryakyn 1 & 1/2" P clamp, and bend a flat piece of aluminum stock to about 90*, drill holes for bolts, and mount it up..there is enough wiring that you won't have to splice extra in there..I mounted mine on the Rivco risers..I did have to get extra length brake lines..get 2" over stock if ya go that route..I went 3, and it's a little to long, but works..I ordered mine from http://www.spieglerusa.com/ ..just call 'em up an tell them you want two inches over stock brake lines..they'll give ya two lines..both coming from the master cyclinder down to each caliper, eliminating the junction block..banjo bolts come with them..a good company to deal with..here's a couple of pics..
