looks like theyre punched in on two sides.Best get some fabricated for other bars and leave stock bars alone.I have to get this done some stage ,as i miss not having bar end weights on the Valkyrie bars I am running on the ol 'Hippo'.
is that the r3t hippo? i've thought of making some sort of puller, have got some grip warmers that go inside the bars and would rather keep the stock bars if poss
I have the oxford hot grips on my 07 standard with valkarie bars I am going to get the Heavy throttlemeister bar ends as soon as i figure out my wiring for the oxfords to the stock harness
sounds good Oz, I was debating between the oxfords and the demons went with the Oxfords had them installed directly to the battery for about 6 months and wonder what I ever did without them, I absalutely love them. I wanted them to be like stock though so I ordered from triumph the subharness with relay and second harness that came with the factory grips so I could wire it all factory like with out cutting my factory harness up. I'm doing something simple wrong just can't figure out what it is. I'm going to slap myself in the forehead when I figure it out and wander how I missed it.
Dave, maybe try a dent puller. Let us know how you like them when your done. I installed Iso grips on mine and also about to get the breakaway cruise so I had to get rid of the heated grips I had.
purple wire with red stripe is power the pink and red are negative you've got to be kiddin me. So I fixed one problem now my controller is getting power it has a red wire(power) black wire(negative) and white wire I think negative. I had power coming out of the harness that feeds the controller and used to have power coming off the same harness that feeds the grips now no more power I check relay and fuse all are good. This is driving me insane. removeing the secondaries and putting on triples was easy. I thought this would be easy and the tripples hard
