Rockt3
.060 Over
Geneva Fl
05 Rocket & 08 Rocket Touring
My old Original 2005 Rocket is not happy these days. It was not starting well. I would only fire up if you cracked the throttle and wouldn't idle. Now it is started popping back through the throttle bodies. It has 95,000 miles on it now. I'm thinking I should look at the valve adjustments and timing chain. I would also like to get my hands on a cam setting tool T3880202 if someone has one they are willing to sell. What are y'all's thoughts on what else should be replaced while I'm there?
The timing chain might be fine but the cam chain tensioner spring could be worn out and check the cam chain slippers while you're in there.
