alpental
Turbocharged
I could use a little advice on how to successfully mount accessories on bikes without any sort of windscreen or flyscreen, just a naked Roadster. I want to mount my phone and use it for navigation, as well as run a charging cable to it, underneath the gauges if possible (gotta check the clearance when turning), or at least just to the right of the gauges.
The plan is to get a Powerlet cigarette socket kit and tuck it either in the now-empty under-seat filter area or the area under the tank where the air intake plumbing used to be.
http://www.powerlet.com/shop-by-veh...et-battery-leads-standard-duty-10-amp/383/754
Next pick up a fast charger, plug it in, and route the end up under the tank and coming out by the gauges, zip tying to a phone mount.
http://www.verizonwireless.com/acce...er-with-fast-charge-technology-for-micro-usb/
Last, pick up a mount, maybe this one:
http://www.revzilla.com/motorcycle/ram-mounts-finger-grip-holder-kit
My concerns are:
My concerns are:
- Will the wind at triple digits blow the mount (this mount, any mount) around?
- Will the wind blow the USB cable out of the phone?
- Will the vibrations cause the phone charger to vibrate out of the socket?
