hombre
Nitrous
- Joined
- Dec 31, 2006
- Messages
- 1,021
I've reset my rev limit to 7850 RPM, in preparation for a dyno run to 7800 on Monday. I need to see how close we get to the theoretical speed (by gearing) of 208 MPH in 5th gear @ 7800 RPM. If we can't do it on the dyno, we sure won't do it on the track.
Other SC R3 owners please note: DO NOT TRY THIS WITH YOUR BIKE!
My bike is specifically set up to make power at higher RPMs. I use much longer duration cams than stock, with much greater lobe separation, have an intercooler that halves my intake charge temps at 20 PSI boost, and a high volume fuel pump that can supply more than enough fuel for that boost. I'm also running 100 octane fuel (my own blend). A "standard" SC R3 will detonate at those boost levels due to excessive intake temps even if it has a high volume fuel pump. That's why the standard SC R3 has the IAT sensor before the supercharger (otherwise it would melt). Mine is mounted in the intake plenum just before the throttle bodies, where it does what it's supposed to.
All that said, she really ripped fine in the cool air this morning! She actually pulls harder from 6500 to 7700 than she does from 4500 to 6500. All that boost doing it's thang!
