Pig9r
Tdragger - The areas on this map that are 14.57 are areas were the ECU uses readings from the O2 sensor to correct the air to fuel ratio to 14.57 to 1, which is ideal for emmissions. If the O2 is reading higher or lower a/f ratios in those areas it corrects it and saves the correction in the ECU. Doing the 12 min tune wipes all of those stored trims so the ECU can learn new ones. So if you make changes to the exhaust, intake or change altitude quickly etc you may need to reset the ECU. The ECU will adapt over time, but by forcing the corrections immediately you won't have to put up with the bike running like crap. If you use tuneboy or a PCIII you should disable the O2 sensor to keep the ECU from correcting your map.
