Jag
To answer all questions
- Bucket was used for water. I washed it before too
- Nobody had an alone time with the bucket
- Not even close to my urine sample
- Did not flush before, it was the same coolant type/brand that I have been using before
@leatal That's what I did. Seem to be running fine and clean.
@Rocket Scientist You just made my day! Knowing there are 2 seals in there means the oil seal is in the right direction. Basically the spring side should be on what you try to contain, that said it's ok as long as it doesn't fall in the engine :O
As far as what that stuff is, I'll probably never know... I put some in a jar and let it settle over night. It is definitely NOT oil. It clumps a little when I scoop it out, I think it could be paper fibers, and it's definitely white.
You could send a sample to BlackStone labs. They will test the oil and antifreeze.
https://m.blackstone-labs.com/
Not cheap but not expensive either. I’ve used them a couple of time. The information they provide on the samples will explain what you have going on.
