Which Eastern Beaver H4 kit?
CWCobra
.060 Over
I have a 2009 R3 Touring model: single headlight, with a pair of auxilliary/fog lights.
My objective is to eliminate the potential for future ignition switch problems by installing the Eastern Beaver H4 relay.
Do my fog lights complicate matters at all? Which H4 kit do I need? The plain "single headlight" model, or the one that also accomodates the auxilliary lights?
Anybody been there done that so I can benefit from your experience?
Thanks,
CW
The single H4 kit is all you need. The aux lights have their own relay and don't go through the ignition switch. Everything in the kit fits easily inside the R3T headlight shell, an easy install.
..before he started to make a specific harness for the standard or classic (two headlights) the relays were left out in the open instead of being hidden under the tank unless you requested longer leads between the relay and the headlight plugs (which I did)..he addressed that issue when he started to make the standard rocket III harness, along with leaving the plugs off the wires ends, enabling them to be put through the small holes in the back of the headlight buckets, then snapping on the plugs on the wire ends..not sure how the touring harness is as far as length or fitting the plug in the bucket..send him an email maybe as he makes them upon order..
