Want to Buy Wanted - Roadster rails
Nick Hanning
Standard Bore
Rocket 3
Have an '05 R3 which has forward placed footboards welded to the rails. Have been told I need Roadster rails and associated gear and rear brake parts to bring my foot position back to thhe centre more or less. What has anyone got ?
Based in UK but dont mind the postage costs for the right parts.
Cherrs
Ishrub
Retired and loving it!
R3 Roadster,Sprint ST 1050 ABS, BMW R100RS sidecar
Cherrs
We need pictures of yours too, as they may be a Triumph factory version in demand still and folks happy to swap for their Roadster ones.
There are 5 different sets of Triumph R3 rails and associated foot controls that will fit ALL model R3s as they share the same engine block used for mounting. Switching between some versions is much easier than others which require the rear brake running gear brake line alteration etc.
Sourcing new parts can be very expensive eg a Touring Footboard with rails and controls onto a Roadster. That member may wish to part with his Roadster ones now. @davidr2023
  • 2004-2009 R3 'Standard' model rails with fwd footpegs
  • 2006 - 2009 R3 'Classic' Model (& Accessory) 'Flat' Footboard rails with fwd controls kit
CLASSIC FOOTBOARD KIT A9758081 - Includes Rocker Gear Lever, big foot brake lever, etc.
I believe they are comparing the Classic Footboards A9758081 (LHS) to the 'Standard' model rails with fwd footpegs (RHS) in the photos not the Roadster, but the Roadster rail is probably at least as low as the Classic but the pegs are much further back.
Same rails as R3Standard with aftermarket RIVCO boards installed in place of the pegs.
  • 2004-2009 Accessory 'Angled' Footboard rails with fwd controls kit
FOOTBOARDS A9758085 - Includes Rocker Gear Lever
  • 2008-2016 R3 'Touring' Model 'Flat' Footboards with fwd control kits
  • 2010 - 2018 R3 'Roadster' Model rails with mid-set footpegs
I know of at least 3 aftermarket rail systems (RAASK & ?? ) and control options over the years with only one still in production on order from a forum member in WA Australia.
If you have long legs you could drop your rails entirely and use fully fwd controls from a big US retail supplier.
On the other hand if you want to go even further back.;):D:cool:
There were RAASK rearsets as well but apparently a little flimsy.
I have some custom made R3 billet rearset mounts with brand new Italian fully adjustable Rizoma rearsets with multiple sets of brake, clutch and footpegs. They come with a Brembo rear brake master cyl, reservoir and linkages hoses etc.
Nick Hanning
Standard Bore
Rocket 3
As promised, pictures of rails and boards, maybe you can tell me what I have ?
20190605_202030.jpg 20190605_202023.jpg 20190605_202044.jpg 20190605_202035.jpg 20190605_202019.jpg 20190605_202012.jpg
Cheers
Ishrub
A simple full side on shot would be easier but fairly sure they are the 'Classic' accessory or sold fitted on Classics when new.
They will look like the top and bottom LHS of this photo comparison.
Not as rare as the 'Angled' footboard rails (that seem to share the Standard peg footrail seen in the RHS of the photo, but you should have no problem finding someone on this forum willing to swap within a month or two.
Ishrub
If the welds are painted over rather than chromed it may be a backyard though possibly perfect job.
It is possible to weld the Touring front or rear stock footboards or a pair of Classic footboards onto a Standard R3 footpeg rail too I suppose.
Mittzy
The Hooligan - Just Doing Stuff
Brisbane, Australia
2010 R3 Roadster 230hp (Matt Black) Called BRUTUS
Alloy to steel not really a viable long term solution. Not really comparable to weld to each other
AdBlock Detected
I've Disabled AdBlock
